Retired_Member's avatar
Retired_Member
Oct 03, 2016
null attacks after update to firmware version: V1.0.4.6_10.0.76 (R6300v2)
I have a Netgear R6300v2 router.  In my router logs I was getting the usual DOS entries, but since updating to firmware version: V1.0.4.6_10.0.76 the DOS entries are all like:
[DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [31.13.90.6], Sunday, Oct 02,2016 00:35:41
Is this 'normal' and is the firewall continuing to block these attempts?
  • Hi Retired_Member,
    Yes, they are normal and that is the indicator that it is blocking the attempts.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Retired_Member,
    Dexter
    Community Team
    • Retired_Member's avatar
      Retired_Member
      Hi Dexter
      Thanks for that. It has put my mind at rest.
      Retired_Member
      I have had these null DoS attacks as well and it was not allowing me access to get to the Netgear Community Forum.  I turned off the UpNp service on the router and it works like a champ once again.
      [DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [96.17.10.19], Wednesday, Oct 12,2016 19:13:19
      [DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [96.17.10.10], Wednesday, Oct 12,2016 19:13:10
      [DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [23.201.67.225], Wednesday, Oct 12,2016 19:12:36
      [DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [96.17.10.56], Wednesday, Oct 12,2016 19:12:28
      [DoS attack: (null)] (-1085517272) attack packets in last 20 sec from ip [23.60.136.70], Wednesday, Oct 12,2016
      This has been happening ever since I upgraded to the newest firmware for the R6300v2 firmware - I have also enabled Wireless Card Access list because after having a lot of neighbors trying to get free wifi it gets old, now with the filtering on - they don't bother me :)  But I have seen these attacks being generated from of all things, my smart tv .. kind of silly seeing DoS attacks from a TV of all things.  The above DoS attacks have been from outside of my local network.
        Retired_Member
        Hi Ninja
        These null attacks seemed to replace the 'usual' entries and changed to null when I upgraded the firmware.  My internet connection also seemed to be slower also with the browser giving a message 'waiting for....'.  I reverted to the previous version and all is back to normal fast speed.
        Robert
