salads01
Dec 20, 2021Initiate
Number of wired devices on wac124
Hi is there a limit to the number of wired devices that can connect to a wac124 in router mode. I know that the limit of WiFi devices is 64 (32 on each band) but what about wired devices
- Dec 21, 2021
Wired
Dec 20, 2021Guru - Experienced User
its a lot more but its more about what your ip range is. if you have an ip range from 192.168.1.1--->192.168.1.254 then you'd have quite a few wired devices you can attach before running into any issues.
