bordonbert
Apr 04, 2018Guide
Odd entries in Attached Devices with WAP connected
Hi guys. The WNR3500 is quite an old model I know but it serves me well with the simple home network I run. (It's apparently so ancient the system won't let me list its model number above!) As ...
- Apr 04, 2018
> [...] The BT WAP DHCP server is set off and it has a reserved IP
> address set by the WNR3500 router outside of the WNR3500 DHCP server
> allocation range but in the same subnet mask as the rest of the network.
That all sounds good. And you've connected one of its LAN ports
(_not_ its WAN port) to a WNR3500 LAN port?
> [...] Even when connected through the BT 2.4GHz wireless it does not
> show up in the administration network display on the Homehub
> administration page.
I don't know what the "administration network display" report on the
BT device is supposed to show. If it's tracking something like DHCP
clients, then it may not show much. Used as a WAP, a router gets pretty
stupid, and its interactions with client devices would be pretty
limited.
> [...] When I don't include it in the reserved address list it shows up
> in the attached devices list 5 times, each with the same correct MAC
> address and each with a different IP address. [...]
That seems (to me) a little strange.
> [...] If I include it in the reserved address list under LAN it is
> then correctly displayed only once with its reserved IP address.
I like that result better, but I can't explain the other one.
> The thing which makes me doubt the correctness of this is that the
> reserved address page is under LAN and it is a wireless device.
"Local-Area Network" and "wired" are spelled differently for a
reason. "LAN" and "wireless" are not mutually exclusive. Admittedly,
the "LAN" Ethernet ports on your router are labeled "LAN", but that's to
distinguish them from the WAN/Internet port, not from wireless stuff.
The wireless connections are not labeled "LAN", but that's primarily
caused by the lack of any place to attach a "LAN" label to a wireless
connection. But it is a common misconception.
> [...] Is it simply that once the Galaxy Ace's connection is into the
> network via the BT WAP the Netgear router then sees it as a wired source
> because that is how it is receiving it?
Exactly.
> If so does that mean [...]
Apparently so.
bordonbert
Apr 04, 2018Guide
Whoops, idiocy alert! Incorrect info in the first post. The Samsung can see the BT 5GHz network but it can't connect to it of course as it is only 2.4GHz capable.
antinode
Apr 04, 2018Guru
limited.
Exactly.
Apparently so.
