sbhakta68
Dec 05, 2021Follower
Offline Satellite
Ok folks, need some assistance. I have one router and two satellites. The system has been up and running fine for several years now. A few months ago I noticed some lag in signal, so I looked up m...
michaelkenward
Dec 06, 2021Guru - Experienced User
Orbi devices are not like the General WiFi Routers (Non-Nighthawk and Non-Orbi) covered in this section. (The Non-Orbi bit is a giveaway.) A lot of questions are generic and apply to most routers. But Orbi stuff has its own quirks.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
