Gogger
Dec 02, 2021Follower
Old routers not good for fiber lines, draws speed down says norwegian expert !
RangeMax Next Wireless Router Gigabit Edition (WNR854T) Purchased: 2008-01-25 That this router is bad for fiberlines i dont understand. The speeds are 1 gb ports and 5g wifi. What are the speed for th...
- Dec 02, 2021
Even though it was gigabit, when it was first released, many of those older devices couldn't saturate gigabit (or even get close).
Even some newer routers, if they were using anything that had to do packet inspection like QoS, access control, parental controls, traffic montoring, didn't have the CPU power to hit gigabit speeds while still saturating the line.
so while it pains me to say it, your "expert" is indeed correct, that router is slowing your connection.
Try updating to something from the current generation. I'd also steer clear of the base model devices.
when you're running full gigabit speeds, you need a router with more CPU capability than just a base model device.
Dec 02, 2021Guru - Experienced User
