Sep 18, 2025Aspirant
Old WNR2000v2/3 - possible to monitor traffic?
Hi, As the title states. I'd like to monitor and block traffic on my ancient WNR2000v2 or WNR2000v3 (I haev both) Netgear wireless routers. The blocking works, and I've selected to log any attemp...
CrimpOn
Sep 18, 2025Guru - Experienced User
Great! A Throwing Star is about $10 on Amazon.
If you can get a command line on the router, try the netstat command.
9014
I'm not in the US, but I did find a Throwing Star replica (?) for $15 plus tax. Interesting! So if I connect my PC to the cable in between the device and the router, I can use Wireshark to see the communications. (I will first have to go to Wireshark University, since I am sure it will have a learning curve).
For the command line, is the intention to find out which ports are open on the IoT device? If so, they are 67 (DHCP) and 554 (RTSP), although I just ran nmap from my PC to query it directly. :)
