stvnmattson
Sep 08, 2017Aspirant
One device does not work
I have an R6400 router. All devices we use (laptops, tablets, phones) work fine on it, with one exception - I have one laptop that when I log in for work I keep getting disconnected. I checked with m...
- Sep 20, 2017
Hi stvnmattson,
It is possible that you may need to forward ports for the work application in order to maintain a stable connection. We recommend checking with your work helpdesk to check for this information. In the event that you were able to gather the information, you can check the links below on how to forward ports.
Dexter
Community Team
DexterJB
Sep 14, 2017NETGEAR Moderator
Hi stvnmattson,
1. What is the firmware version of the router?
2. Are you connecting the laptop via wired or wireless?
3. If wireless, on which band (2.4GHz or 5GHz)?
4. Is it the connection to the WiFi network that drops or are you using a VPN and that is the one that drops?
Dexter
Community Team
DexterJB
Sep 17, 2017NETGEAR Moderator
Hi stvnmattson,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- stvnmattsonSep 18, 2017Aspirant
Thanks! Yes I am. The firmware version is v1.0.1.24_1.0.18.
I am trying to connect wirelessly. If I use a wired connection, it works just fine.
I am not sure how to determine which band it is using.
I log in for work, so I assume its a VPN. I can connect to work and access email, internet etc, but when I try to fire up my main work application, I lose the connection.
- DexterJBSep 20, 2017NETGEAR Moderator
Hi stvnmattson,
Dexter
Community Team
- DexterJBSep 25, 2017NETGEAR Moderator
Hi stvnmattson,
Dexter
Community Team
