Snowslide
Jul 15, 2019Follower
One pingable attached static device is missing from table
I've been forced to update from Win7 to Win10, with a new PC and I'm trying to reinstall and reconfigure my network, which monitors a bunch of remote devices. One of the devices is an Nport seria...
- Jul 15, 2019
The "Attached Devices" list is not based on an active network scan. Best guess is that this device does not make much (or any) traffic to or through the router (Internet) so it will never become visible in the list. There are several more examples, like simple Web managed switches which don't show up for the same reason.
schumaku
Jul 15, 2019Guru - Experienced User
- schumakuJul 15, 2019Guru - Experienced User
Have missed mentioning that the static IP is another key factor - as there is no DHCP, the router does not recognize the device, too.
