minioo
Aug 26, 2021Follower
Online LED wont light up
Hi, I’m using an AC1200 WiFi Cable Modem Router, Model C6220. I’m pretty sure I have ISP, and I have all the required cables connected to power. (Power adapter connected, Coaxial cable connected, an...
michaelkenward
Aug 27, 2021Guru - Experienced User
You are "pretty sure" you have the ISP? Doesn't sound encouraging.
Perhaps this is a clue:
minioo wrote:
The only LED lights I see are the power, ethernet, and downstream(although its blinking).
According to the manual that says "The unit is scanning for a downstream channel."
Support | NETGEAR
What does your ISP say about your service? Have you talked to them?
Your modem.router won't get very far if they haven't set up your service.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
