np2200
Oct 06, 2018Aspirant
only 3 devices can connect to my WNR2000 V5
Hi,
I was wandering whether I can change any setups enabling me to connect other devices to the router. For now just 3 Ip addresses (for 1 laptop and two smartphones) can be given by the router...
- Oct 07, 2018
> I just attached the whole page,
I don't see it.
> I can see access point mode on top of the adminstration page,
If the WNR2000v5 is in "access point mode", then there is some other
router which is acting as your DHCP server, and you may need to look at
that.
> [...] I didn't undrestand your second question.
Which question? Copy+paste is your friend.
At what, exactly, are you pointing your web browser to get to these
settings?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Rear Panel". Do you
see the (yellow) "Internet Port"? To what is it connected?
You might also want to look in that manual for "Use the Router as a
Wireless Access Point".
np2200
Oct 07, 2018Aspirant
Hi,
- The problem is for the fourth client. I can even change the laptops, which ever turns on first gets the IP and the other one will have no access to the internet.
- At the setting I can only see that DHCP mode is on. I cannot go through LAN setting since it's deactivated as you may kindly see in attache pic.
BR
N
antinode
Oct 07, 2018Guru
> - At the setting I can only see that DHCP mode is on. [...]
Where can you see that? How, exactly, are you getting to the
settings?
> [...] I cannot go through LAN setting since it's deactivated as you
It would help to see the whole web page instead of only a small part
of it. Is the WNR2000v5 configured as a wireless access point? What's
connected to the WAN/Internet port of the WNR2000v5?
- np2200Oct 07, 2018Aspirant
>-Where can you see that? How, exactly, are you getting to the
settings?As per attached pic.
>- Is the WNR2000v5 configured as a wireless access point? What's
connected to the WAN/Internet port of the WNR2000v5?I can see access point mode on top of the adminstration page, I didn't undrestand your second question.
- antinodeOct 07, 2018Guru
I don't see it.
that.
settings?
