jp560
Apr 17, 2017Aspirant
Only getting 94 Mbps WIRED with N300 Wireless Router WNR2000v3
I Only get 94 Mbps WIRED with my N300 Wireless Router WNR2000v3, even though my provider's speed clocks at 230 Mbps when directly connected to my modem. My provider is Xfinity. Does anyone know what ...
- Apr 17, 2017
The specs for the N300 show that the wired ethernet ports are 10/100, not gigabit, so 94 Mbps wired is to be expected.
netwrks
Apr 17, 2017Master
The LAN/WAN ports support 10/100 Mbps only. Either downgrade your ISP Service, or upgrade to a router that supports 1000 Mbps LAN/WAN ports.
- NutOnABikeApr 17, 2017Tutor
... another option is OP could get a GS105 or GS108 gigabit switch, then connect the router and his wired connections to it. That would provide greater than 100 Mbps for both wired and wireless.
- netwrksApr 17, 2017Master
Nothing gained adding a switch into the mix with current hardware setup. The connected speed on the switch to the client would be a gig (if there is a cient NIC card to support it), but the important part is the uplink connection between the router LAN port and the switch, it will only be 100 Mbps (bottleneck), as that is all the router can support. At the end of the day, the router can only support 100 Mbps wired. Wireless does not benefit from a gigabit switch, if the the router, as in this case, supports the client wired and wireless environment..
No, the N300 has a theoretical max of 300 Mbps wireless but is limited to 100 Mbps wired. Thus having the gigabit switch upstream prevents the wired bottleneck by using the switch for the wired connections. The N300 would only be used for wireless, which will be > 100 Mbps, assuming environmental conditions allow it.
