Harsh2691's avatar
Harsh2691
Follower
Jun 03, 2022
Only usb light is flashing on Netgear R6350
I tried to reset the the router and still only usb/Flash drive led is flashing. When I switch off and turn on again, then internet and usb led flashes for 2 seconds and this keeps repeating after 15 seconds.
  • FURRYe38's avatar
    Do you have a USB drive connected or no?
    Is the USB feature enabled on the routers web page?
  • michaelkenward's avatar
    michaelkenward
    No power LED?
    If that is off, this thing may be dead. The first thing to check is the power adapter. If you have something with the same output, see if that brings the router back to life.
    Harsh2691 wrote:
    I tried to reset the the router ....
    Why did you reset the thing? Were you having problems of some sort?
    Tried another reset?
