Xgharetx
Sep 15, 2016Aspirant
Opening NAT types
I am not very good at electronicstormy and such. But I recently had to buy a new router and got the WNR2000V5. Set it up and it worked great, only issue is that now my game console, Playstation 4, is ...
- Sep 16, 2016
Xgharetx wrote:
I believe this is the same one.
http://www.zyxel.com/us/en/products_services/p_660r_compact_series.shtml?t=pThat clearly states that it's a modem router. So, the problem is that the Zyxel is blocking the ports from being opened. You either need to put it into bridge mode, if at all possible. Or, alternatively, you need to put the WNR2000 into AP Mode (via ADVANCED > Advanced Setup > Wireless AP).
Xgharetx
Sep 16, 2016Aspirant
TheEther
Sep 16, 2016Guru
