Rickwur
Mar 07, 2021Aspirant
Opening ports and public ip
Have a orbi 6 rbk753 ax4200 Trying to network to my defender security system . Need to open ports 80,5000,9000,18004 Told ip is private needs be public Please help
Rickwur
Mar 08, 2021Aspirant
rbk is conected to a spectrum modem
I can view my camers home with a app on my phone (defender clear vu ) wifi but not away .
working with net gear tech we were able to open the ports needed told me possibly the ip adress 172. is private and not public a class B .
thanks any thoughts
antinode
Mar 08, 2021Guru
Thanks for the details. So, if I plug "a spectrum modem" into my
search engine, I'll get all the information about _your_ modem?
> [...] told me possibly the ip adress 172. is private and not public a
> class B .
From "172.", I can't tell.
> Plug that address into the form at: https://whois.arin.net/ , and see if
> it is a public or private address.
You can see that address, and I can't. Which of us, do you think,
should try that experiment?
> [...] or one at your (unspecified) ISP, if they use carrier-grade NAT.
> https://en.wikipedia.org/wiki/Carrier-grade_NAT
Ask your ISP?
- RickwurMar 08, 2021AspirantI talked to my isp
They told me the 172. Ip is one created by my net gear router it not there’s
Can the ip be changed in my router ?
Thanks all- antinodeMar 08, 2021Guru
> there'sOk. And if I could see what it actually is, then perhaps I could
tell you something, too.> Can the ip be changed in my router ?
Sure. _Which_ IP address would you like to change?
Please review this thread, and look for "?". Those are questions.
If you answer them, then perhaps we could make some progress. If you
can't/won't answer them, then I have better ways to waste my time.- RickwurMar 09, 2021AspirantThank you
I appreciate your time
When I go on my pc connected to my network
What’s my ip it’s a 172. Ip
When I go to can you see me per that ip it shows ports 80 5000 9000 18004 not open ?
I need to be able to view my security cameras remotely.
My phone app uses my ip to log in remotely and I can’t ?
Until I got the net gear router I was able to ?
Was told by net gear that the 172. Ip is private but it’s there generated ip according to my isp
Net gear did open all ports and I can view home WiFi but again not remotely
Thanks very
