kman5574
Nov 11, 2022Tutor
opening ports on Nighthawk R6330
Hi, I need some help with opening ports on my router. I have a rowing machine that's been connected to the internet since I got it 3 months ago with no issue. Last week I couldn't get it to connec...
- Nov 14, 2022
Have you tried a different dns provider? Or enabling ipv6?
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4Does it connect to the wifi but just not find an internet connection?
Did anything change with the router during that process?
Nov 13, 2022Guru - Experienced User
What rowing machine is it?
What modem/gateway is your router connected to?
- kman5574Nov 13, 2022Tutor
It’s an Aviron Impact rower, the modem is an Arris TM1602 through Spectrum.
- plemansNov 13, 2022Guru - Experienced User
Are you using IPv6?
Any netgear armor or parental controls?
Or access controls?
- kman5574Nov 14, 2022Tutor
I'm using IPv4, no armor or parental controls. I was using access control with it allowed but I also tried turning access control off, it still doesn't work.
