kman5574's avatar
Nov 11, 2022
opening ports on Nighthawk R6330
Hi, I need some help with opening ports on my router.  I have a rowing machine that's been connected to the internet since I got it 3 months ago with no issue.  Last week I couldn't get it to connec...
  • plemans's avatar
    Nov 14, 2022
    Have you tried a different dns provider? Or enabling ipv6?
    Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
    CloudFlare 1.1.1.1 and 1.0.0.1
    GoogleDNS 8.8.8.8 and 8.8.4.4
    Does it connect to the wifi but just not find an internet connection?
    Did anything change with the router during that process?
