MMERIDETH
Sep 21, 2018Aspirant
OPENVPN will not connect
For whatever reason, had vpn working last week and now it does not. have tried everything i can find but am unclear what a PK1 is and if I need it. connecting thu xfinity business modem/router with...
- Sep 22, 2018
V1.0.4.18_10.1.49
I got it to work.
Ended up turning the VPN off
restarting router
turning VPN back on
downloading new cert information
installing new files on client
works fine at least for one computer
working on another computer today
Thanks!
michaelkenward
Sep 22, 2018Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
- MMERIDETHSep 22, 2018Aspirant
V1.0.4.18_10.1.49
I got it to work.
restarting router
turning VPN back on
Thanks!
- michaelkenwardSep 22, 2018Guru - Experienced User
Well done. I asked about the firmware because Netgear recently released a bunch of updates that accommodate changes in support for VPN.
You have the latest version, so your R8000 should work with OpenVPN:
R8000 Firmware Version 1.0.4.18 | Answer | NETGEAR Support
