Retired_Member
Oct 09, 2015OpenVPN with iOS
Brief history: I upgraded to Cox Gigablast and they included a Netgear R6300v2. I had a VPN on my previous router (ASUS Dark Knight) that I used for conneting securely in places that aren't secure. ...
- Oct 14, 2015
It doesnt support OpenVPN for iOS or Android. You should see the highlighted options below if R6300v2 does support Smartphones.
Retired_Member
Oct 14, 2015It does. Under advanced tab, advanced setup. You have to setup a DynamicDNS obviously and then turn on the VPN option.
