vt15
Apr 01, 2025Aspirant
Orbi and netgear ac1750 r6350, verifying my config is correct
Hello, I have an old Orbi with one remote station, and I added a netgear ac1750 to my network to extend the reach of my orbi and have some ports for wired connection of a desktop.. I have a devic...
michaelkenward
Apr 02, 2025Guru - Experienced User
Is this AC1750 the R6350 in your subject. (Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.)
If so, is it in access point (AP) mode?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
That is how to get rid of the double NAT issue that seems to be troubling you.
What is Double NAT? | Answer | NETGEAR Support
Disclaimer: Just another user with time on their hands.
