Puch96
Feb 08, 2021Guide
Orbi AX6000 using Satellite with wired connection - Slower than Wifi connection?
Hello. I had a quick question. I connected ethernet cable to the satellite Orbi unit RBS850, and conencted ethernet to laptop. I did notice that when running speed test with laptop connected via e...
Feb 09, 2021Guru - Experienced User
you might get better results in the actual orbi ax forum
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Zablalbaz
Feb 09, 2021Star
Thanks Plemans! I couldn't find the Orbi specific forum. I just thought it was removed and all we had left was "Nighthawk" and "Non-Nighthawk" forums. I'll bookmark it!
