dcallahan
Apr 08, 2021Aspirant
ORBI Configuration
I am confused by this ORBI. Can connect via iPhone - but trying to connect on the web through orbilogin.com tells me I am not connected. When I clieck on my wireless connect link I see my main WIFI a...
Apr 08, 2021Guru - Experienced User
I've never been a huge fan of the app. Half the time it logs in with my fingerprint and the other half the time I need my fingerprint plus the login to the router.
Did you try the forgot password option (if you set it up during the initial install)?
https://kb.netgear.com/31016/How-do-I-recover-my-Orbi-admin-password
dcallahan
Not yet - I was not sure if the same password for the app and the router admin. Do you know if the same?
