jfoxny's avatar
jfoxny
Tutor
Apr 06, 2021
Orbi connection drops when renaming the 2.4GHz SSID
I have the Orbi RBR50, RBS50 and two RBW30s for a 4000sqft house plus two car garage. I recently updated them all to their latest respective firmware as of 4/6/2020. Previously I had setup separate SS...
  • jfoxny's avatar
    Apr 07, 2021
    I found a simple workaround in this post. Essentially you leave the SSIDs unified but stop broadcasting the 5GHz SSID while connecting IoT devices which only support 2.4GHz. Tried it with one of the problematic devices and it worked. Going to move on to the others next.
