Silvconv
Apr 15, 2021Aspirant
Orbi cpm[atibility
2 questions. Will orbi 6k work with 2.4g devices?
2nd ques, im told change ssid and pw exactly to old router and devices "should" be compatible. Ques is if old router has dual band, 2.4 and 5g, 2 ssid's, which ssid should orbi be set at? If it matters, plan on installing a NG modem only with orbi. Thanks in advance.
1 Reply
- SilvconvAspirant
Sorry. Meant compatibility
