magsh112
Mar 29, 2021Tutor
Orbi crashing after firmware upgrade
I have an RBR40, which is not even an option to enter in the model field above. Anyway, its worked fine since the day I installed it, until today. A day after executing the firmware update I was sent...
ST054
Mar 30, 2021Initiate
After installing firmware update V2.6.2.104 on 03/28/21, RBR40 router goes offline several times a day. This requires router reboot to bring online. What's the fix to improve stability?
magsh112
Mar 30, 2021Tutor
I did a hard reset on both my router and satellite (paperclip in the small reset hole on back of hardware) and reconfigured it all from scratch. It's worked just fine since, though. Stability back to what it was prior to firmware upgrade. knock on wood.
- ST054Mar 31, 2021Initiate
Stability restored after hard reset of router and satellites (paper clip into device reset opening). Thanks for the solution!
