Anesinano
Oct 21, 2020Aspirant
Orbi ethernet outlet
My modem is in the basement, I got a ethernet outlet upstairs main level and that cable that runs from the outlet behind the wall is plugged into my modem in the basement, now, can I plug in the orbi ...
- Oct 21, 2020
> Im wondering if i can [...]
I can't see your cable or where it goes. If it connects the right
things, then it should work. If a short cable works, then a longer
cable (up to 100m) should work.> Orbi ax4200
Not a model number. Look for "Model" on the product label.
> Modem model is actiontec c3000a
Normally, that's a modem+router. If you want to use it with a
separate router, then you should configure it as a modem-only (sometimes
called "bridge mode").
Anesinano
Im wondering if i can just plug my orbi router into the ethernet outlet on the first floor(living room) via ethernet cable....that outlet(the ethernet outlet) in the living room has an ethernet cable (obviously since it’s an ethernet outlet)running down to my basement, (behind the walls) and is plugged into my centurylink modem..is that the same as if i had the orbi router in the basement plugged to my modem via ethernet cable?
Orbi ax4200
Its an 802.11n and 802.11ac wifi router
Orbi ax4200
antinode
Oct 21, 2020Guru
> Orbi ax4200
- AnesinanoOct 22, 2020AspirantOk bro thank you appreciate it
