cyoung01
Apr 14, 2021Aspirant
Orbi Gateway issues .... 192.168.36.1
Hello all. I have had my Orbi RBR750 WiFi 6 set up for some time now. I love it, and have not had a single issue. Today after a reboot of my network. I noticed that my gateway changed from its original 192.168.1.1 to now 192.168.36.1. Didn’t really think anything of it. I was able to get on the internet. However, I am not able to log into my app unless if I use connect anywhere. Using a network scanner it tells me that the gateway is 192.168.36.1. But when I type that into my browser I don’t get a result. The original (1.1) log in gives me access. Even when checking Advanced> WAN setup the range is between (192.168.1.1- 192.168.1.256).
In the end, I just want to make sure my network is running normal and I am able to access my app properly. Curious if anyone had any thoughts.
Thanks!
Thanks!
No RepliesBe the first to reply
