Filis
Oct 16, 2021Aspirant
Orbi pro behind UDM router | Dynamic Vlan via radius
Dear community, dear netgear,
Team,
I set up a UniFi UDM as a router with a radius server. Behind the UDM, I am running a Orbi Pro on firmware 3.3.0.122 as an AP. The challenge is that I would like to dynamically assign a vlan to Orbi clients based on the radius authentication on the UDM.
For now, the authentication works, but the ips assigned to clients do not match the correct vlan address range, even though the tcpdump on the UDM indicates the right vlan in the accept message. so it seems the Orbi pro just doesn’t “understand” / “convert” / “translate” the radius reply correctly to its clients.
I found some documentation on dynamic vlan for other netgear products but non of it for the Orbi Pro. The configurations mentioned for other products (dynamic vlan, …) are not available in the Orbi pro Settings, so I cannot select anything but the radius ip, port and shared key. If I select a vlan, only the selected address range is used, even if the radius credentials and the tcpdump would suggest a different address range.
How can I configure the Orbi Pro to dynamically select a vlan?
Thanks
Team,
Thanks
Netgear has set up a community forum specifically for the Orbi Pro (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifiThank you
- FilisAspirant
Addition: The Orbi Pro is a SXK80 and a SXS80
You'll find more help and support information in that forum
Good Luck.
