Sbennumi
Apr 01, 2021Aspirant
Orbi r50 has location wrong
How do I fix my Orbi’s location. A few months ago it started saying it was located in New Jersey and it has messed up all my local channels, I don’t really want to watch news or sports from Philadelph...
Sbennumi
I have xfinity. I just checked the ip addresses geolocation and it states that it already is the correct location.
Apr 01, 2021Guru - Experienced User
Is it in the correct location?
And you didn't answer what modem/gateway you have?
- antinodeApr 01, 2021Guru
> How do I fix my Orbi's location. [...]
In which frame of reference? Are you moving it around?
> [...] it started saying it was located in New Jersey [...]
"it"? Your router has no clue as to its location. Who, exactly,
believes that it's in any particular place, right or wrong?> [...] I just checked the ip addresses geolocation [...]
"checked" it _how_, exactly?
> [...] and it states that it already is the correct location.
"it"?
Various organizations claim to keep records of locations for IP
addresses and/or wireless-network SSIDs, which are collected in various
ways, with various degrees of accuracy. Apparently, one of them has a
bad location for some kind of identifier associated with your router.If your TV service has it wrong, then your argument is with them, not
with your router.
> And you didn't answer what modem/gateway you have?I doubt that that matters.
Various web sites act as if I'm situated 20-odd miles away, at the
offices of my ISP. I'm not, but the worst problem this error causes me
is needing to type my actual ZIP code into various forms before I get
useful data on store locations, and so on.- plemansApr 02, 2021Guru - Experienced User
Doubt all you want. a family members internet is a LTE gateway and usually says the location is several states away. Its why the question is asked.
- antinodeApr 02, 2021Guru
> [...] Its why the question is asked.
Mentioning that when asking the question might have been helpful.
