Ethesis
Jan 17, 2021Tutor
ORBI RBR 10 has website connection problems
I have gotten the same error for multiple sites asking me to “Login to [site domain here] Your password will be sent unencrypted” With a prompt for a username and password. The moment I switch to cel...
- Jan 21, 2021
Its not a command/recommendation. Its just my signature with the devices i have
Ethesis
Jan 19, 2021Tutor
https://www.facebook.com/media/set/?set=a.10164751564420523&type=3 Pictures of all that I have on the Orbi.
Jan 19, 2021Guru - Experienced User
Your gateway is a modem/router combo device. Leaving 2 routers in router mode on your network. It causes a double nat which I've seen cause those errors.
https://kb.netgear.com/30186/What-is-Double-NAT
Options? (only use 1)
1. Put the gateway in modem only mode. Contact the isp for help with this
2. Put the netgears IP address into the gateways DMZ. Again, the isp is the expert on their devices so contact them for help with their settings
3. Put the netgear in access point mode. This disables its routing functions and leaves the ISP router running them. You can still use wireless/ethernet, its just being managed by the ISP device. Tends to be the easier route but you do loose some features on the netgear.
- EthesisJan 19, 2021Tutor
"Put the netgear in access point mode. This disables its routing functions and leaves the ISP router running them. You can still use wireless/ethernet, its just being managed by the ISP device. Tends to be the easier route but you do loose some features on the netgear. "
How do I do that from the app? Or is there another method?
Thanks.
