DuckFans10
Mar 27, 2021Aspirant
Orbi RBR 750 not found after factory default reset
Hello, I reset my Orbi to remove Xerox to refresh then the system is completely refresh. I tried new setup system then Orbi is not found. I tried searching for information that help with Orbi not fou...
DuckFans10
Mar 28, 2021Aspirant
I have a question. I found my RBR750 is disconnected on my Orbi app. Should I log on PC to turn it back on? This is my first time doing Manuel fix word on router. So can I have any advice on what should I do?
- DuckFans10Mar 28, 2021AspirantI managed to get back into Orbi. I would not call this a trick at all. I used factory reset and manuel the Orbi app on iPhone 8. As soon I saw the WiFi up, it does some cut in, but I only need a signal on my phone. So I jump to Orbi app and it skip not found and I am in firmware searching. It show error so I decide to skip straight to end. I got in and check if I can reboot firmware and I cannot. Somehow, it automatically update itself already. I guess I am okay.
