kev160967
Feb 08, 2021Aspirant
Orbi RBR20 Bandwidth control and AP/Router mode
Recently installed a 3 node RBR20 system and started migrating from my previous system, a Draytek router and access point. Generally been a good experience, but one aspect that is killing things is the lack of bandwidth management. On the Draytek system I was able to specify a per-client bandwidth cap across the connected clients so that no one client could hog the available bandwidth. I don't seem to be able to do this on the Orbi. I still have the draytek router with my wired clients attached to it, but now everything attached to the Orbi comes through as a single connection for the purposes of bandwidth management. I've read through the forums and it seems like Netgear has no immediate plans to add support for this. I'm wondering if I'd be better switching the Orbi from router mode to AP mode? I think if I do this then all the wireless clients would once again appear as individual connections on the draytek router, just as they do when connecting via the old Draytek AP? Would I lose out on anything by doing this though? For example, will the Orbi's mesh coverage still work the same way, etc? Anything else I should be aware of?
Thanks,
Kevin
No RepliesBe the first to reply
