NadineSky
Nov 03, 2020Follower
Orbi RBR20 Slow Ethernet Connected Speeds
So I got a new router from rogers and hooked up to my gb ignite wifi. Since hook up my connected ethernet which is right next to all routers is very slow - I used to get 700mbps and now under 100...
antinode
Nov 04, 2020Guru
> [...] I got a new router [...]
Not a very detailed description of that device. Has it a maker and
model number? What did it replace? To what is it connected?
> [...] from rogers and hooked up to my gb ignite wifi.
Not all of your readers are certain to have heard of Rogers Ignite TV
service.
> Since hook up [...]
What, exactly, is connected to what, exactly? (Hint: If a device has
different types of Ethernet ports, then "connected to device" is not
enough detail.)
Cascading multiple routers can cause multiple problems. If your "a
new router" can be configured as a modem only ("bridge"), or eliminated
entirely, then using the RBR20 as your only router might work better.
Alternatively, configuring the RBR20 as a wireless access point
instead of as a full-function router (leaving your (unspecified) "a new
router" as your only router) might help.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Use the
router as a WiFi access point".
> I did read something [...]
Thanks for the helpful link.
