JulietFalcon
Nov 10, 2020Aspirant
Orbi RBR20 slow upload speed
I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload sp...
Nov 11, 2020Guru - Experienced User
What modem do you have?
If you hardwire into your modem and test upload/download speeds what do you get?
that's kind of key. Its pointless to troubleshoot the router if the issue is the modem. so lets make sure it works first.
