KRey
Aug 07, 2021Aspirant
Orbi RBR350 Ethernet speeds much slower than wireless speeds
Hi all, I’ve just set up my Orbi RBR350 in my new home. I have it connected directly to my NBN NTD box via a cat6a Ethernet cable. The wireless speeds are as expected ~600mbps however, when I connect ...
olympos1625
Aug 10, 2021NETGEAR Employee Retired
Hi KRey,
Please check if you have SmartByte installed on your laptop. Please check the link speed of the LAN adapter while connected to the router( wired).
https://www.youtube.com/watch?v=0UZXx1avODI
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
KRey
Aug 10, 2021Aspirant
Hi Oliver,
Thanks again for the reply.
I've confirmed that there is no SmartByte installed on the laptop.
Also confirmed that the link speed of the LAN adapter while wired to the router is 1000/1000 (Mbps) per your video linked.
Wonder what it could be if not those above?
Kind regards,
KRey
