KRey
Aug 07, 2021Aspirant
Orbi RBR350 Ethernet speeds much slower than wireless speeds
Hi all, I’ve just set up my Orbi RBR350 in my new home. I have it connected directly to my NBN NTD box via a cat6a Ethernet cable. The wireless speeds are as expected ~600mbps however, when I connect ...
olympos1625
Aug 10, 2021NETGEAR Employee Retired
Hi KRey,
Please check if you have SmartByte installed on your laptop. Please check the link speed of the LAN adapter while connected to the router( wired).
https://www.youtube.com/watch?v=0UZXx1avODI
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
olympos1625
Aug 12, 2021NETGEAR Employee Retired
Hi KRey,
Thank you for your confirmation. Please plug your laptop directly into the laptop and see what speed are you getting.
Oliver
Community Team
- KReyAug 12, 2021AspirantHi Oliver,
Did you mean my laptop directly into the NBN NTD box? If so, I will do that and let you know.
Thanks - olympos1625Aug 13, 2021NETGEAR Employee Retired
Hi KRey,
Yes, that's right. Please keep us posted.
Oliver
Community Team
