CalSmith's avatar
CalSmith
Follower
Jan 19, 2021
Orbi RBR40 and RBS20 not connecting over wireless bridge
Is it possible to connect an RBS 20:  1) by wire out of wifi range of other orbis?  2) is it possible to connect the orbi over a wireless bridge?
Details:
I have an RBR router that I am trying to connect via a Ubuiquit PTP bridge to a RBS20 satellite on the other end, but it does not want to connect and stay connected.  It is on the very edge of  wireless range of other Orbi satellites.  Setup: from a tp-link switch connected to the router, I ran a cable from the switch to a Ubiquiti LiteBeam Gen2 PointToPoint bridge which on the other end of the bridge I have a wire connecting to the RBS20.  I was able to get it to link, it showed a wired connection, but it went down and has not worked since.  I wonder if it had a wifi connection that allowed it to connect without using the bridge at all.
Thanks.
1 Reply
  • plemans's avatar
    Try disabling daisy chain in the settings.
    Maybe the orbi is picking up just enough of the other signal and trying to default back to a daisy chain setup.
    Or you can try  turning down the broadcast power of the orbi's to see if it helps.
