lyrussel
Mar 14, 2020Initiate
Orbi RBR40 Firmware Update
I got an email this morning saying that a new firmware update is available - Latest firmware version: v2.3.5.34. I logged on to my Orbi and it says it is running V2.3.5.30. So I click on check butt...
- Mar 15, 2020
Perfect - thank you!
geobehr
Mar 14, 2020Aspirant
Same here, RBR20 current at .26, email says .36 available, both web login and app say 'no new firmware updates'
- antinodeMar 14, 2020Guru
> Any ideas how I can upgrade to the latest?
Or almost any other...
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions."Beta" or "Hot Fix" versions typically will not be applied by the
automatic update scheme.- lyrusselMar 15, 2020Initiate
