Fortunatum
Apr 06, 2021Aspirant
Orbi RBR50 IPv6 connection type
How can I connect modem-Motorola MB8600 with router Orbi RBR50 using internet protocol IPv6? My ISP uses a dual stack transition method that enable IPv4 and IPv6 host to communicate with each other. ...
Apr 06, 2021Guru - Experienced User
Did you try the auto-detect?
- FortunatumApr 07, 2021AspirantI tried both Auto Detect and Auto Config but got a lot of disconnect issues. Just looking for an educated answer to the problem. I will return my Orbi otherwise and try a more reliable brand.
- plemansApr 07, 2021Guru - Experienced User
Do you run into issues directly wired into the modem with a pc?
Did you contact cox to find out their ipv6 settings? (I don't have cox to do so)
https://www.cox.com/residential/support/ip-version-6.html
