RedDogSD's avatar
RedDogSD
Orbi RBR50 set up as AP only help
Hi, could use some help. The cable/internet connection comes into the house in a metal box in the closet. That is where the cable modem is and currently where I have my RBR50 main router but the signa...
  • antinode's avatar
    antinode
    May 29, 2021
    > Do you agree with me that using the Airport in Wireless mode might
    > just cause more interference? [...]
       It might.  Many things are possible.  If you don't need it, then I'd
    leave it off.
    > [...] I already find that using both satellites in my 2500 sq foot
    > home is too much so I keep one offline.
       Sounds to me as if more wireless wouldn't help.
       Wireless range/coverage/interference all depends on details like
    wall/floor construction (metal boxes, ...), and I know nothing about
    yours.  Running the experiment should yield more reliable information
    than any advice you'll get here (especially from me).
