nicolerosenberg
Nov 09, 2021Follower
Orbi RBR850 Good Streaming on TV, Spotty Zoom and FaceTime
Hi. I am trying to troubleshoot my Orbi AX6000. I have excellent download and upload speeds and have no trouble streaming to my Amazon Firesticks. However, our Zoom and FaceTime calls are very spotty....
michaelkenward
Nov 10, 2021Guru - Experienced User
Is that the RBR850 mentioned in your subject? (AX6000 is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.)
Many issues are generic and apply to most routers, but in this case the RBR850 is an Orbi, which is not in the category covered in this section General WiFi Routers (Non-Nighthawk and Non-Orbi). Those are Netgear's basic routers andare nothing like the fancy Orbi Wifi 6 stuff.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
If you do post in the appropriate section, you could add some details about the rest of your network. Your modem/router, for example, could be relevant.
