GreyBeard1948's avatar
Mar 27, 2021
Orbi RBS40V. Netgear sent firmware update
I have an Orbi Rbr50 WiFi router with 2 satellites. One of the satellites is an Orbi Voice rbs40v. Netgear sent an email to upgrade the rbs40v but every time I try to update the firmware I get an erro...
  • plemans's avatar
    Mar 28, 2021
    You are on the current firmware version.
    I know that there was issues over the last few days with the auto-update server but you're on the most current so you should be good.
