GreyBeard1948
Mar 27, 2021Aspirant
Orbi RBS40V. Netgear sent firmware update
I have an Orbi Rbr50 WiFi router with 2 satellites. One of the satellites is an Orbi Voice rbs40v. Netgear sent an email to upgrade the rbs40v but every time I try to update the firmware I get an erro...
- Mar 28, 2021
You are on the current firmware version.
I know that there was issues over the last few days with the auto-update server but you're on the most current so you should be good.
GreyBeard1948
Mar 28, 2021Aspirant
Was reply incorrect? I just need to know why I keep.getting an error message when I try to check for new firmware. In the past when I Checked the firmware it would state I have the most current update or would tell me to update. Do the router and the voice satellite have to be on the same firmware version?
I am not good at this and really need some help. My WiFi numbers are fine as is everything else.
Mar 28, 2021Guru - Experienced User
- GreyBeard1948Apr 07, 2021AspirantCan someone tell me why when I try seeing if I have an update on my Orbi application I get an error message and not the message that your system is up to date? I do not understand what would cause this ad I have an excellent WiFi signal.
Thank you
