cbrabthy's avatar
Apr 09, 2021
Orbi Router Firmware RBR50 won't update but RBS50 Satellite Firmware Updated just fine w/ Manual Upd
- Was able to perform a Manual Update of my Orbi RBS50 Satellite Firmware to v2.7.2.104. YAY!!!   When I attempt the same process with the RBR50 Router:   - I get the message that v2.7.2.104.img ...
  • cbrabthy's avatar
    cbrabthy
    Apr 09, 2021
    Ok...I had to go through about 7 firmware update .img files starting with the one closest to the version I with which I purchased the router.
    Once I got to v2.3...I was able to skip to the current 2.7...version.
    All done! Thank you for your help.
    Corbin
