cbrabthy
Apr 09, 2021Tutor
Orbi Router Firmware RBR50 won't update but RBS50 Satellite Firmware Updated just fine w/ Manual Upd
- Was able to perform a Manual Update of my Orbi RBS50 Satellite Firmware to v2.7.2.104. YAY!!! When I attempt the same process with the RBR50 Router: - I get the message that v2.7.2.104.img ...
- Apr 09, 2021
Ok...I had to go through about 7 firmware update .img files starting with the one closest to the version I with which I purchased the router.
Once I got to v2.3...I was able to skip to the current 2.7...version.
All done! Thank you for your help.
Corbin
Apr 09, 2021Guru - Experienced User
You'll be able to skip. (not sure at exactly what point without looking it up)
there was a change in there needed to enlarge the partitioning for the increasing firmware size.
cbrabthy
Apr 09, 2021Tutor
Corbin
