DCP4971
Jul 27, 2021Luminary
Orbi (Router Mode) using as DHCP server
Hi, sorry if this is a numpty question.. I'm running RBR50 in router mode (with 2 RBS50's) behind a Virgin Media (UK) cable modem. My question is: should Orbi be running as DHCP server or should I ...
DCP4971
Jul 29, 2021Luminary
To be fair to VM, thier boxes are fairly straightforward (if limited in functionality), at least in tracking down the settings (BT, I recall were pretty shocking and I don't blame you for leaving them in their wrappers. Sadly don't have that choice with cable, I don't think). Am pretty sure we had the previous VM hub running in Modem only mode for a while - I got the shiny new 1g upgrade late last year, so have never tried it on the Hub4, but the navigation is the same.
That's a great suggestion of moving everything to Orbi first, thanks. I'd probably have done it the other way round and had everything offline for longer.
I've got a few things that only work on 2.4ghz but it's never seemed to be too much of an issue when setting things up previously. Ring is defo one, the Arlo cameras/lights are the other - and Arlo throws a massive hissy fit, putting loads of warnings in the app about not working on 5ghz network trying to set them up, but they then work anyhow because there is 2.4ghz network available.
michaelkenward
Jul 29, 2021Guru - Experienced User
Sounds good. I just wanted to give you advance warning. Anyone with a BT Homehub could have wasted hours looking for that setting.
Been there, done that, many times. I beta stuff for Arlo and have been down that road. Sounds scarier than it turns out to be.
As you say, ignoring the warnings seems to work.
- DCP4971Aug 01, 2021Luminary
So, I've done the deed, moved the VM box to modem mode and it wasn't that difficult. Got all the other,stuff moved to Orbi first. PlayStation speeds still slow.
Then, after a few hours, I noticed a few iOS apps were really sluggish, at best, which was puzzling (Facebook media were just grey blocks, BBC sport app not showing any news stories). Was getting great speed test results and pop iPhone onto cellular and problems went away..
Next, thought, well, I'm up early, let's do a factory reset. Had read a few posts here about QoS issues with Orbi and the built in Speedtest causing issues.
So, reset and got the 2 satellites registered and everything back online. App issues then disappeared and Orbi admin navigation is much less sluggish.
But, still PS5 speed is slow.
Anyone got any views on the QoS point with Orbi and use of the Speedtest functionality, which I read drove some kind of dynamic QoS? I've not run a Speedtest in Orbi since the reset, wasn't sure if I should..
Thanks
- michaelkenwardAug 02, 2021Guru - Experienced User
The reasoning behind slowness with QoS enabled is that anything that requires the router's processor to work on the traffic eats processing power that would otherwise go into moving traffic around.
The notion is that you avoid that if you turn off QoS, traffic metering, parental controls and so on.
I have no idea if there is a different take on this in Orbi devices.
I would try to get help with that in the section where most Orbi users hang out.
https://community.netgear.com/t5/Orbi/bd-p/Orbi
