aweskk's avatar
aweskk
Follower
Jan 31, 2021
Orbi Satellite shows poor signal - While device is next to it
Orbi Community,
I transitioned to the Orbi Mesh Wifi (RBK30 system) with one Orbi and one satellite. The issue that i have is that the Satellite is taking devices that are closer to it, however it is not improving the connectivity on those i.e. a TV right next to the Satellite will keep on buffering the content.
I have tried diabling and enabling the Daisy Chai, enabling the other Wifi improving options and decreasing the signal strength on the 2.4Ghz network and its a net zero effect on the original issue.
Any help will be highly appreciated.
1 Reply
  • My issue has been solved. Working great now for about a week.
    I Reduced the transmit power to 25% on my Orbi RBK854 system turned all the AX features back on.
    All our old and new Chromebook and Pixel devices Wi-Fi connections remain stable with good throughput while next to satellite.
    The problem was I have too many Orbi satellites for my space 3080sqf house 3 floors tall, one per floor except for the top floor. My house was built in 2006 without ethernet but plenty of unused phones jacks in every room. I placed an Orbi RBS in my 2nd graders room using the ethernet on it for stable connection for zoom video school. Turns out 4 Orbi satellites broadcasting at 100% so close together is not a good thing.
    Cut & pasted from my post in google bug tracker.
