AMGS
May 19, 2019Tutor
Orbi with Sky in the UK
Before I consign my Orbi and 2 satellites to the scrap heap, in desperation, has anyone found a stable configuration to use Orbi with Sky fibre? I am connected by Ethernet to the Sky router with its w...
- May 19, 2019
AMGS wrote:
Thank you for the response - in turn:
1) it’s quite a big house around a central large stairwell
2) the first satellite is about 12 feet from the router and the second is about 15 feet from the first---The Satellites should be minimum 30ft apart/from main router as well. Try moving these further apart
3) haven’t tried
4) wireless (I think) - there’s no wired connection between the Orbi units. Enable daisychain topology checkbox is ticked
5) house is old (early 19 C) brick and timber----Brick does an excellent job of blocking wifi. An Excellent Job of it. If you have a solid brick wall in between router/satellites its going to make the wireless backhaul really sketchy. I'd look into wired backhaul whether you use ethernet runs or using powerline adapters to allow a wired backhaul. I know people with concrete/brick have issues with the backhaul, it'll work for awhile and then struggle until they reboot. I know the whole premise of orbi is wireless backhual but some houses are going to struggle with it. You can do the wired backhaul and retain the seamless roaming and still have great coverage with Orbi.
Problem I see for you is if you go powerline, is that it struggles with older wiring. This is true for the homeplug av2 devices.
May 19, 2019Guru - Experienced User
More details on the issue would help.
You have the orbi in AP mode so it has no routing function.
How large of an area are they covering?
How far apart are they?
Does it work better if you remove 1 of the satellites or even just run the router alone (for testing)?
Are you using the wireless backhaul or wired backhaul?
House materials? wood/sheetrock/brick/foil lined insulation?
- AMGSMay 19, 2019TutorThank you for the response - in turn:
3) haven’t tried
5) house is old (early 19 C) brick and timber- plemansMay 19, 2019Guru - Experienced User
3) haven’t tried
Problem I see for you is if you go powerline, is that it struggles with older wiring. This is true for the homeplug av2 devices.- AMGSMay 19, 2019TutorThanks again. I’ll try moving the satellites further away. Power line - cable from the back of the Orbi router and then via Wi-fi from the wall to the satellites or cables again? Hopefully the wiring isn’t too bad...
So there isn’t anything about the Sky configuration particularly which is problematic?
