jefferis
Jan 29, 2021Guide
Orbing stops sending wifi without a reboot?
The last couple of days we have awakened to find NO wifi signal coming from the Orbi. We have had the unit about 3 years. The unit is on, but doesn't broadcast a signal till I do a reboot. It is fed an incoming wifi to internet connection via a wireless antenna to a tp custom wireless router. That hasn't been a problem until now.
| Hardware Version | RBR50 |
| Firmware Version | V2.5.2.4 |
| GUI Language Version | V1.0.0.375 |
| Operation Mode | Router |
You might try updating the firmware. the most recent is the 2.7.1.60 version.
Update the satellites first and then the primary router.
https://www.netgear.com/support/product/rbr50
https://www.netgear.com/support/product/rbs50
