GR613
Jan 18, 2021Follower
Outdoor ORBI Wifi
Hi,
What is the best outdoor wifi extender product to use if I have an ORBI system? I am reading where it's the ac3000, but that seems not to be available for purchase anywhere. Is this the best or are there equal alternatives? Thanks
1 Reply
The only orbi outdoor satellite is the RBS50Y.
It tends to go in and out of stock.
I've seen others use a standard orbi satellite and use a weather proof box instead of going with the outdoor version.
Tends to be cheaper
