ScottyVA's avatar
ScottyVA
Follower
Feb 06, 2021
Output / ethernet port for a JGS524 switch
Need to switch out a TS 16 switch with a JGS524 unmanaged switch.  Which port would the output ethernet cable go to?
1 Reply
  • > [...] Which port would the output ethernet cable go to?
       Roll a dodecahedral die and flip a coin?
       An Ethernet interface is bidirectional; there are no input ports or
    output ports.  All the ports on the switch are equivalent.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get some.  Read.  Finding nothing about an "output
    port" should serve as a hint.
